Possible Habitat Advice
MSGGrunt
Good idea or bad idea to consider a freezer/cooler truck box as the basis for a camper build? Size is 8'x16'. Not sure on the weight but given a freezer/cooler box I would bet heavier than a "normal" box. $2,500 US seems reasonable if the FG140 long wheelbase model can handle the weight. Ideally a composite box that is lighter would be better, but? I wasn't going to go a full camper build, but if the freezer boxes make a good base for a camper build because of how they are insulated I may change my mind or if too heavy to start with I may ditch the idea.
564065224_1282571293627863_4449435142332505954_n.jpg530249792_1008449187922540_5937205258344858206_n.jpg532365846_1288772755984271_5783993674651777974_n.jpg
I almost went this route. There is a better one at 14ft. (this one was in good condition, for sale for $3000)
It will keep you nice and cool in Summer. :)
The box will obviously be a lot lighter when you take that boat anchor off the front. Might ever be able to onsell it.
A standalone unit like this may not be the lightest option out there, but I would think they would be ideal as a removable camper setup, which is what you will be doing.
Bit of work replacing the barn doors at the rear, but easier than building an entire box.
My thoughts exactly SkiFreak. I was away from the truck when I saw this add and it seems Gator70 is correct, 14' would probably be a better fit. A 16' box would be extending about 6 1/2' past the rear axle centerline.
benrickky
