Potentially buying a 1996 Trooper.. what to look for?
Lake-O
So I've stumbled across a virtually rust free 1996 Trooper Limited. Which in Michigan is pretty rare. I checked it out today at lunch but didn't have time to go for a test drive. Body is decent shape for a 20 year old truck with 176k miles. Everything works inside (heated seats, power mirrors ect.). The owner said something along the lines of the transfer case works but something came unplugged? Like I said I didn't get a chance to fully investigate. What should I inspect should I go forward with buying this truck? Anything to stay away from? Thanks.
In general that is a pretty good year, just look at it like any other used vehicle. A few notes - the 3.2L is reliable, might have some lifter clatter that is more of an aesthetic problem than anything. Is it auto or manual trans? Manuals are stout, autos are okay if serviced regularly (but many are not). Unfortunately there is not a dipstick for the auto trans, you have to remove a plug from the side of the trans to see if the fluid is good.
Bodies are pretty rust resistant but check the frame for rust, especially rear crossmember up under the bumper. Part time MUA transfer case is stout, about the only thing that can come unplugged from it is the connector for the 4WD indicator dash light.
Its an Automatic. I thought I read somewhere the transfer case is electronically actuated? Or is it a strictly linkage operation? Ill have to wait until I see it again if it has Shift-on-the-fly
Yes, a 96 has SOTF. My knowledge of the SOTF system is a little hazy because my 95 doesn't have it, but I believe the transfer case is lever actuated, but there is also a vacuum actuator on the front axle. Maybe that is what he was talking about.
auto trany
even if the trans has been maintained u r at/close to the end of it's service life, I commonly find these in the boneyard with no visible outside damage and have worked on many to include replacing the trany, I would keep in the back of my mind that a 3k bill is in the near future when making any deal. When u test drive the unit c how hard it shifts/slips between/in gears and u can get an idea of how soon it will need to be rebuilt (if it's bad then use that to lower the price and even if it's not u can still use the high miles as tool to bargain).
A $3K transmission bill would send a truck like this to the scrap yard pretty quick.
a 20 year old car with 176K from a company known to have a poor resale value. Hmmm, i can't see this costing more than $1000. Just buy it, change the all the fluids and enjoy it.
ELShockley
