Chorky
As the title suggests. I cannot seem to make a decision on keeping with industry standard of LP, or go the diesel route, or some sort of combination between the two.
LP:
US industry standard
lots of parts/appliance available - though not always good quality
relatively simple
can be dangerous (volatile)
can be expensive / difficult to find good LP sources nation wide and in Canada
not as efficient as other options especially with elevation and temp changes
Diesel:
Higher efficiency
Can have large on board tank to last significant amounts of time
easier to source diesel than LP
not as volatile
costly systems
not industry standard meaning sourcing parts could be more difficult
would require 12v fridge/freezer route - more extensive electrical system
would require LP system if wanting to cook with gas
could introduce cold weather concerns
I'm sure theres a ton of other pros/cons, but these are the primary ones that pop up in my head for now.
LP:
relatively simple
Diesel:
Higher efficiency
not as volatile
costly systems
