Eugene the Jeep
I’m looking to provide safe power to my Dometic fridge which will be in my Offroad trailer. I wired up a 7 pin connector on my Jeep that includes a 10 gauge aux power post in the trailer junction box. This wire goes directly to the starting battery and has a 40 amp circuit breaker.
From the 7 pin junction box on the trailer tongue I plan on wiring up dometic’s HWK-DC which is a wiring kit with two 12 volt outlets. The kits included wiring is also 10 gauge and has an in line 15 amp fuse. So from the fridge, to the junction box, through the 7 pin trailer plug in, to the Jeep starting battery is not more than 30 ft. of 10 gauge wire. I think the Dometic wiring kit came with 25 ft of 10 gauge wire.
So my questions are thus:
1. Is it safe to run power for a fridge through a 7 pin trailer connector?
2. Where should I put the in line 15 amp fuse? Can I put it near the junction box on the trailer tongue or should I remove the 40 amp breaker near the battery and put it there? This would make the aux power pin on the 7 way dedicated to the trailer, correct?
In the future I plan to install a solar/battery setup so the trailer can be totally independent from the Jeep.
All comments and suggestions are greatly appreciated.
