Premier Power Welder - $825 OBO plus shipping
WoldD90
Complete Premier Power Welder - originally off a CJ7 jeep.
Complete with the 160 amp saddle mount alternator, welder control box, heavy duty voltage regulator, throttle adjuster, and 25 ft leads. This works perfect and is very easy to weld with (especially if you are just learning to weld). It also has a 110 volt plug to run power tools (grinders, drills, etc.)
The alternator will run on a v pulley or a serpentine belt, you can pull it off your existing alternator, a new belt is recommended when installing. You can adapt this to nearly any truck by making or buying a bracket to mount the alternator. Includes 25 foot welding leads - $825.00 OBO
