Price Drop $10K: Launch Edition Gladiator with 6.4 Hemi Swap & Major Overland Build - Lightly Used & Needs New Home
angoodp
Price: $120,000. Mileage: 31,000
A 2020 Gladiator Launch Edition is basically a fully loaded Rubicon but with every option included. Jeep built only 4190 units in honor of Jeep’s Toledo, Ohio factory – area code 419 - and as part of the roll-out marketing plan for the launch of Gladiators (which sold out completely on day 1).
The original intent for this build was to travel the Trans-America and Pan-American Overland routes, then expand over to Africa, Australia, and New Zealand. A change in life's plan requires selling this family favorite - oh well, things change! The rig’s customization has roughly $85,000 invested in upgrades and parts alone. It is fully customized for Overlanding, off-road, off-grid use and has significant rock-crawling capability but has been used gently during its build process and is in superb condition.
Hemi Swap Gladiators for street use routinely go for $125-$225K. Specification details for this custom build are:
ENGINE, DRIVE-TRAIN, STEERING & SUSPENSION,
America’s Most Wanted - HEMI SRT 6.4L 505 Package
6.4L/392 cubic-inch displacement | 505 horsepower / 475 lb-ft torque
  • Cast Iron Block With 4-bolt Main Caps
  • Aluminum Cylinder Heads & Forged Crankshaft
  • Powdered Metal Rods with Floating Pins & Hypereutectic Aluminum Pistons
  • 10.9:1 compression ratio allows for pump gas use
  • 4.090-inch bore and 3.724-inch stroke
  • Hydraulic roller camshaft
  • Eight-Speed Heavy-Duty Mopar® Automatic with Fluid Supply Line Kit, 6061 Billet Heater Delete and 185° C Thermostat
  • DEI Titanium Exhaust Wrap with LR Technology
Adams Driveshaft JT Gladiator Rubicon Rear 1 Piece 1350 CV Driveshaft: Extreme Duty Series
Adams Driveshaft JT Gladiator Rubicon Front 1350 CV Driveshaft OEM Flange Style: Extreme Duty Series
Dana 44 Axles with Tru-Lock Front & Rear Lockers & Front Axle Disconnect
4.88 Re-Gearing Ring/Pinion Differential
Front & Rear Rubicon Differential Covers
Front Sway-Bar Disconnect
Apex 2.5 Ton Tie Rod & Drag Link Assembly - Apex Steering Damper Bracket
PSC Hydraulic Power Steering Conversion Kit
Falcon Nexus EF 2.2 Fast Adjust Steering Stabilizer
Synergy Front Track Bar & Sector Shaft Brace for Steering
RockJock – AntiRock Heavy Rear Sway Bar Kit (1 1/8” Bar) with Daystar 3/4 Inch Rear Level Kit
Clayton Off Road 2.5" Overland Plus Lift Kit
Clayton Offroad 3.5" Triple Rate Front Coil Springs
Clayton Offroad 3.5" Triple Rate Rear Coil Springs
Rock Krawler 3” Bump Stops
Teraflex Falcon Series SP2 3.3 Shocks
BUMPERS & PROTECTION
Westin WJ2 Bumpers: Stubby Front & Full Rear w/ Tow Point
Custom Engine Skid Plate Mounts
Westin Front Skid Plate
Rusty’s Sidestep Frame Mounted Rock Sliders
DV8 Rear Bed Sliders
Artec Full Bellypan Aluminum Skid Plate (JT4150)
Artec Front & Rear Fender Liners for Piggy-Back Shocks
Front Fender Slim Chop Trim Kit
WHEELS & TIRES
Teraflex Nomad Off-Road Wheels: 17” x 8.5” w/ BP 5x5”
Metallic Black; Offset: 0” & Back Spacing: 4.75”​
TPMS, Rash guards & Lug nuts​
Yokohama Geolander MT G003 37” Tires (37X12.50R17 124Q)
ARB On-Board Twin High-Performance Air Compressor
LIGHTING & POWER
Oracle Flush Mount LED Taillights
S-Pod Bantam MX HD (BX-HD-UNI-84)
LED Lighting Strategy:
  • 2x Rigid A-pillar trail lights
  • 2x Rigid LP4 front trail lights
  • 2x Squadron widespread fog lights
  • 2x KC rear LED backup lights
  • 6x KC C-Series C2 2” scene/work lights
  • 6x KC Cyclone Rock Light kit
  • AVS Aeroskin LightShield Hood Protector
Redarc Dual Battery Charger & Fuse Kit with Dual Optima Yellow Top Batteries
Redarc 120-Watt Portable Folding Solar Panel
Z-Automotive Tazer JL Mini
Front & Rear Camera Systems
STORAGE & RTT CAMPING
Decked Truck Bed Drawer System
ADD-Lander Overland Bed Rack with RotoPax Mounts
TuffStuff Alpha II Hardshell Tent with Annex & Mat
RhinoRack Pioneer Cab Roof Rack
RhinoRack Dome 1300 Awning & Side Panel
Waterport 8-gallon Water System
AluBox Storage Box
Goose Gear – Complete Rear Seat Replacement
On-Board Power for Dometic CFX Fridge
Original 3-passenger rear seats available
COMMS & NAV SYSTEMS
& Antenna
WeBoost Cell Booster System
67Designs Dashboard Mounting
RECOVERY GEAR
Warn 8000# Winch/Heavy-Duty Hook
RotoTrax Traction Boards
HiLift Jack, Base & Recovery Lift Kits
Midland Radio
angoodp
Am ready to consider reasonable offers on this build and have dropped price by $10K
Price: $110,000 Located in Ocala FL and willing to assist with relocation.
SANelson
