***Price Drop*** 2019 Turtleback Expedition for sale $21,000
mcbunnyinmontana
2019 Turtleback Expedition trailer for sale in Billings, Montana. For the record, this is an amazing trailer and the only reason for selling is due to a knee surgery that made it difficult to get in and out of the RTT. Husband and I have since upgraded to a van build and no longer have use for the Turtleback, though it would be sweet to tow the Turtle with the STO Beast.
Here are the specs:
Base build package
- expedition chassis (welded 2 x 3 galvanaized tube steel chassis with 11 g aluminum floor system
- axleless suspension 3500lb rated timbren
- front and rear 2in receiver hitches
- expedition trailer aluminum skin and box including front, sides, valances, doors, nose box, side boxes and turtle tailgate emblem
- slide out kitchen including partner steel stainless stove with dual 10000 btu 18" burners, Dometic deep well stainless steel sink and faucet with tempered glass lid
- onboard systems control panel (blue sea circuit breaker panel, battery power disconnect, usb/12v chargers, voltmeter, water heater switch, exterior and interior lighting controls
- 7 pin trailer connection (charge line, brake controller, running/signal/reverse lights)
- dual stainless steel fold down prep tables (18" x 36" on tailgate swing, 16" x 25" prep table on kitchen door
- 42 gallon water tank (lockable fill door)
- water pump
- Dometic water heater (***replaced to to water freezing damage)
- Shower (lockable exterior use shower with dedicated valve control, shower hose and head)
- Primary propane tank (11lb)
- Tailgate with spare mount and rotopax mount
- Nose jack (2000lb swing away tongue tack
- Safety systems (trailer break-away break activation switch, dual towing safety chains, adjustable rear stabilizer)
Custom Upgrades:
- Dual battery electrical system (GXL 125 C automotive wiring, blue sea marine grade components, dual trojan group 31 AGM deep cycle batteries for combined 210 amp hours of power, battery boxes, blue sea 6 circuit fuse box, blue sea dual battery disconnect, 6 amp heavy duty battery charger
- 2000 W pure sine wave inverter
- Redarc 12 V charger
- Additional USB charge port and 12V socket mounted in main storage area/kitchen
- accessory propane tank with bracket
- Getaway roof rack (4 powder coated steel rack with storage area with single rear door)
- Expedition composite kitchen and interior panel upgrade (marine grade high density polymer material, waterproof and UV stable)
- Turtle back signature suspension (Icon reservoir shocks, custom wound dual rate progressive springs and daystar products kevlar bushings
- custom tires (Cooper SST MAXX 255/80/17)
- custom wheels (Aluminum 7 spoke 17" FJ wheels)
- wheel adapter/spacer
- Expedition tread plates (on top of storage boxes, trailer roof)
- Expedition topo graphics
- Max coupler articulating hitch (6000lb rated)
Soft Goods:
- Tepui 3 person Autuna Ruggedized RTT (green) with weather shield, annex
- James Baroud Awning over kitchen (52" x 95")
Please message for additional questions or pictures!
mcbunnyinmontana
Here are the specs:
Base build package
- water pump
Custom Upgrades:
Soft Goods:
TNielson-18
