Cllaframboise11
I am looking to sell my Harker EDC topper. This thing will take your overlanding abilities to the next level. It is a killer setup weighing just over 300 pounds. This topper comes with an installed 200amp hour battery , 400 watt inverter, 5 switches to control interior and exterior lighting. 480 watts of solar on the roof and cross bars to hold any surf board / kayaks. With solar alone the battery would run a 55liter refrigerator forever. I used it for entire weekends running starlink, refrigerator lap top / monitor and never saw the battery level get below 60%. The set up and take down is less than 2 minutes. You can keep your mattresses and pillows in the Harker and still fold it down completely with no issues. I used the 4 inch lost horizon mattress.
When not sleeping you are able to push the sleep platform out of the way (it is on gas struts) and have full standing room. I am 6’7 and cannot reach the top with my arms fully extended. The sleep platform is 7.5’ long and 58” wide. So it almost the length of a king and width of almost a queen mattress.
I am located in Chesapeake Virginia. Spent over $16k on this and drove all the way from Virginia to Salt Lake City. Willing to part ways for $11k firm. It fits on a long bed Tacoma (6ft bed). I have a crane in my detached garage, so if you can get here it should be pretty easy to mount this onto your truck, it mounts using four of the brackets as seen in IMG_3098.JPG. So as long as your truck has a rail system you should have no issue mounting.
Additional accessories:
Roof mounted Vent fan
Truck connect
Wagan 400 watt inverter (for AC electric)
Rear visibility window package. (can use your rear view mirror and see everything behind you)
18X20 pass through door on passenger side. (i used this to access my refrigerator while being outside of the truck
Hatch table bracket and cables. (Pretty cool design by Harker. The rear hatch of the camper doubles as a side table and is very strong.
Roof crossbars and brackets
200 Ah Dirt Circuit Deep Cycle LiFePO4 In-wall Battery
Control Panel with Six Switches, Two 12v CLA, Two USB Charging Ports
Wagan Tech 45 Amp DC to DC Battery Charger + Solar Charger
Three Interior Lights on two zones (Upper/Lower) with Switches on Panel
Two Exterior Side Lights with Switches on Panel
Truck connect
DIRT CIRCUIT 480 PRO POWER PACKAGE
Two Dirt Circuit 240 Watt ETFE Roof-mounted Solar Panels for a total of 480 Watts200 Ah Dirt Circuit Deep Cycle LiFePO4 In-wall Battery
