PRICE MODIFIED: Ford E-350 NEW High Top, 7.3L Diesel Motor & 4x4
pbetts
All the parts that matter in this rig are NEW! New 7.3L diesel motor, new 4x4, new high-top, new build! Less than 10,000 miles on everything!
Located in Moab, UT.
This is the van you want to buy if you want your money to go into something strong, reliable and capable. I have owned many van and camper platforms and this is by far the best platform. It will truly go to 4x4 areas and provides excellent traction in loose or snowy conditions. It has a new motor, 4x4 and build; everything works as it should and will outlast your travels. Keep reading for details about the van and build. Ask me all your questions!
The Van:
· New Remanufactured Ford 7.3l Power Stroke Diesel Motor, purchased from Ford via Blackwater Engines. Installed by Moab's Ford dealership, early 2023, at 245,150 miles
Motor is under 2 year/unlimited mile warranty.
camper.
· New HD gear reduction starter
· New high output alternator
· New radiator
· New 4x4 conversion from Advanced 4x4 in SLC (installed a 246,840 miles)
Whole new front end, new Dana 60 front axle, a New Process 271 transfer case with high and low range, front manual locking Warn
hubs, new Spicer drive lines, new front suspension with Bilstein shocks, new steering, brakes and 4-5 inches of lift
· New American Racing 17in Wheels with new Toyo Open Country AT III tires (LT265/70 R17)
· New rear Bilstein HD shocks
· New paint job (coming soon)
· Aftermarket stereo with Bluetooth, car play and backup camera
· Cruise control
· Air Conditioning
· New flooring in cab
· New door seals
· Glass has been resealed
· Rear tow hitch
· Clean title in hand
· Standard areas for rust on Econoline vans was treated/coated with Por-15
· Odometer reads 247xxx miles
The Buildout
· New Tuffport fiberglass high top, installed by Wasatch Overland in SLC
· High top was insulated (R22) and finished by Wasatch Overland
· Lizardskin Sound deadening throughout the van
· Insulated with Havelock Wool (excluding hightop, that was insulated by Wasatch Overland)
· Vinyl plank flooring
· Espar S2 d2l diesel heater with easystart pro controller
· 200AH Lithium Battery
· 1000W Pure Sine Inverter
· 175-watt flexible solar panel
· DC-DC charge controller (charges house batteries while vehicle runs and charged vehicle battery via solar)
· Renogy M1 device monitoring system (solar, battery and inverter communicate to it for easy monitoring)
· 30 gallon fresh water tank
· Aquor Exterior Water Fill inlet
· Hose Attachment for pressurized water out the back of the van (i.e. outdoor shower/rinse station)
· Electric water pump with electric gauge
· Dometic 2 burner propane cook top
· Iceco 47qt single zone fridge freezer
· MaxxAir 7500 fan
· 6 dimmable LED lights wired in 2 zones
· Underbed Light
· Rhino Rack awning
· Exterior LED Porch Light
· Sliding Bed Frame allows for couch-mode or bed-mode
· Unused mattress, 62” wide x 69” long and 5 inches thick with a hinge so it folds up on itself for couch/stow mode
· Plenty of under bed space (garage) for storage (height of 32”)
· 2 upper cabinets that are easily removed
· All cabinet and drawer hardware is soft-close and push button latches
· Headliner shelf with cargo net
· Cabinets and drawers are constructed of plywood, no MDF or particle board
· Cabinet fronts are High Gloss White melamine faced particleboard.
· Ample storage in galley cabinet
· Swivel Passenger seat
· Lagun Table that can be used as a table or locked away for more counterspace
· Ruuvi temperature monitor devices, interior and exterior
· Wall panels have been upholstered with vehicle headliner material.
· Window coverings for cab windows and MaxxAir Fan from Vanmade Gear
Asking $73,000. Delivery can get negotiated.
More photos can be found here: https://drive.google.com/drive/folders/1r76beY1TE-OW8QUxP-9FwlyT9Ayg7d__?usp=drive_link
  • Like
Reactions: zip
pbetts
I had planned on getting a new paint job from my body shop in Moab. He recently became the only shop in town that does body and paint work so he has just been slammed since I talked to him in August initially about it. He wouldn't have time until over the winter when things slow down. So, I lowered the price to $90,000 to accommodate that fact.
iStan814
