Motivated seller! 6.8L V10 Engine
Timberline Vans Build. One of Tim's last builds. I've only used the van three times. Many of the van's features have yet to be used. It's a true off-road van, and I'm going in another direction with my camping set up.
Base Timberline Vans Conversion Info
Ford Standard 5" Coil Spring 4x4 Conversion
Hellwig sway bar 7718
Chassis Options
Timberline 5-7" Rear lift custom leaf springs - 2200lb spring rating
Sliding door hinge modification
Warn hub lockouts
Custom Timberline High Capacity Fuel Tank GFX T16 Matte Black
TPMS Sensors
Lug Nut Kit Black - 14mm x 1.5
Rear Carrier/Roof Rack/Ladder/Bumpers
Aluminum Square tubing - Roof Rack
Mandrel bends - Roof Rack
Timberline Custom Ladder - plus a second mounter ladder
Rear Tire Carrier Reboot - Custom Fab Alt swingarm, latch, extension, sandblast, powder coat, etc
Timberline Full Size Aluminum Box
Front and Rear Heavy Duty Aluminum Bumpers
Metal Running Boards
AirLift 5000 air bags with onboard compressor and remote
High Top
Fiberine 30" High top Raptor Paint Trailering Top
Metal Framing - For Bed Sliders
12 x 43 Fiberine Hightop Sliding Windows
Interior - Paneling + Misc
Carpeted Board Sliders for Bed Platform
Full Paneling Upper and Lower -Interweave Material – Includes Extensive Carpet Trimming Around Panel Gaps
Front /Rear Storage Area Carpeted Platforms
Interweave/Landeau Hightop Ceiling Fabric - Outsourced to Colo Upholstery
Cabinetry
Bed Platform Including Cushions
Kitchen Galley
Upper Cabinet left Rear
Appliances
NR751SS Norcold 12v / 110v Fridge
2 Burners Sink Stove (never used)
MASO High-end Folding Tap Faucet Water (never used)
Manchester Tank 5 lb. cap. Steel Type 1 Empty LP Tank (never used)
Dometic Air Conditioner
Maxxair Fan
Electrical
Onan 4000 Generator (45 hours)
Renogy 100W Panel // R+R Existing Panel and Charge Controller
12V RZBK- LiFePO4 - 138Ah - 1.76kWh - Battery
Lighting System - Dimmable LEDS, In Cabinet Lighting, Overhead, USB Ports
Electrical Panel - bus bars, breakers, fuse panel, battery cutoffs, jumper switch, etc,
12V 40A DC to DC On-Board Battery Charger SKU: RNG-DCC1212-40-US
Xantrex Freedom Xc 2000 True Sine Wave Inverter/Charger - 12vdc - 120vac -2000w/80a
Xantrex 808-0817-01 Freedom X/XC Remote Control Display w/Cable
Plumbing
Thetford 92860 Porta Potti 135 , White (never used – still in packaging)
5 gallon grey water tank –
Precitrade Shurflo Fresh Water Pump, 12 Volts, 3.5 Gallons Per Minute, 45 Psi
Camplux Outdoor Tankless Water Heater (never used)
Kickass Shower Curtain Awning (never used)
MISC
Overland Vehicle Systems Awning (never used)
Chassis Options
Warn hub lockouts
TPMS Sensors
High Top
Cabinetry
Kitchen Galley
Appliances
Maxxair Fan
Electrical
Plumbing
MISC
