Darkrider
As you guys know i recently started a build on a 2015 Jeep Patriot. I also recently picked this truck up from a fellow car club member who needed a newer vehicle to get back and forth to work. So i traded him my '91 Sierra C1500 for this. I have a two part build plan well... Planned. The Jeep will be used for soft road type adventures and the Jimmy will be used places that the Jeep may not be able to handle. Ideally i would like to find a small tent trailer that is lightweight enough for both vehicles to pull. Ultimately i will not be surprised at this point if i end up building a lightweight teardrop style trailer that can be shared between them. Either way that particular component of the build will be sorted once the tow rigs are. Enough side tracking on the subject here is some info on the Jimmy.
Specs:
1986 GMC Jimmy Sierra classic (K5 full size)
305 High Output with Th700R4 trans
Np208 Transfer case
10 bolt front and rear diffs (3:08 with G80 rear)
It has an interesting mix of options in it from what i have seen so far.
Power Locks but manual windows. Did not know that was a thing with these trucks
Air conditioning
AM/FM Cassette deck with the corner speakers in the dash
Known repairs needed so far:
Front brakes
Fuel tank (has a leak in it possibly from mounting strap rub through)
Front and rear bumpers
Grille repaired or replaced
Rear window
Exhaust
Rocker panels replaced at some point most likely with square tubing rock slider style
May need an oil pressure and temp gauge. Though i seem to recall mention of the temp needing to be plugged in so will look into it in warmer weather.
and a couple pics for now.
Planned upgrades:
Hidden receiver hitch behind stock bumper (may change to the older 81-82 bumper with turn signals on it to relocate the signals to be easier to see with grille guard)
rocker panels replaced with rock sliders
stock rear bumper in place of step bumper
rear receiver hitch
Winch on receiver mount as it will allow me to use one winch for both ends of the truck
CUCV style front grille guard on stock bumper (may mount turn signals to guard if old style bumper is not used)
Specs:
Np208 Transfer case
Air conditioning
Front brakes
Rear window
Exhaust
Planned upgrades:
rear receiver hitch
