Propane bottle mounts?
Rezarf <><
I have an 11# propane bottle that I am trying to figure out how to secure, searches left me looking for more.
I want to hard mount this tank externally. I have looked at several RV mounts but none look that solid.
What have you guys done/seen?
Thanks for your time.
Drew
Tucson T4R
Here are a couple pics of how my propane bottle is mounted on the front of my King Kamper trailer. Let me know if you are interested in different angles.
Nuclear Redneck
This is the Navy spec for compressed gas bottles and I think it might be a good standard for off road mounting as well. The purpose is to prevent the bottle from being ejected as a result of shock. I'll try to get a picture of one at work tomorrow if you want.
All compressed gas bottles require mounting which prevents vertical and horizontal movement. This means a belly band around the bottle and a collar at the top of the bottle (also known as grade B shock mounting).
Cheers,
Tate
BigAl
I've found that an old steel milk crate holds a propane tank perfectly. A heavy duty plastic crate may work too. I have the crate bolted down to the front of my trailor and a ratchet strap to hold the bottle down.
lowenbrau
x2
It might look a bit cheap but its easy to bolt a plastic milk crate down and then bungy or strap the bottle in.
Come to think of it, its the 20 lb ones that fit well. I don't know what you'd do with an 11 pounder.
DaktariEd
2005, 2006 Tech Course Champion: Expedition Trophy
My AT has a small propane cylinder like that...and an excellent bracket.
Not sure if it's a commercial bracket or not. Send a PM to Martyn or Mario...
HTH...
:sombrero:
PS...photo swiped from AT website...don't think they'll mind...
Rezarf <><
Thanks guys, mine is tall and skinny. Maybe 9ish inches in diameter. I like the band clamp that should work well. I like how it sits above the weld seam to keep it in there.
Anyone else?
Thanks!
Drew
Steve Curren
I too would like to find a band clamp that would fit the tank, after that making a platform for the tank would be easy enough. Does anyone know where a band clamp like Ed has shown can be had?
Steve Curren
It seems like you have once again solved a problem, I will contact them tomorrow and make sure that the size I need is one they have.
Thanks,
Steve
Green Ganesha
11# is a less-common size, but CampaUSA manufactures these brackets for their trailers:
Contact Chris Cole at Campa, and I'm sure he could set you up.
