Propane Tank Flow question
srgsng25
i was recently given a set of taller tank think that are 10 Gal tanks i along with double connecter
1. can i connect several gas appliances inline i want to get away form throw away tanks
can we install 2 aux port for appliances like 2 lanterns i am not entirely sure how i would plumb all this as i have only ever played with a propane tree and i can run my 2 stoves and lantern off of that
any thoughts?
Mike S
Sponsor - AutoHomeUSA
You need a manifold with separate valves for each appliance. No mystery - go to a plumbing supply shop for the parts.
dwh
Tail-End Charlie
There is "high pressure" and "low pressure". You need the appropriate regulator for whatever appliances you are hooking up. Some appliances have internal regulators.
If everything you have is "low pressure", then all you need is one regulator and assorted hoses and some brass fittings. (And shutoff valves are good too.)
To eliminate the little bottles usually takes a special adapter. Like this:
http://www.amazon.com/Mr-Heater-Thr...?s=home-garden&ie=UTF8&qid=1332915872&sr=1-28
Goldenbora
