I'm looking for the right way to setup propane in my trailer. I plan to use a 20lb tank and have a couple uses. I have a propex propane heater that has its own 2 stage regulator. I would also like to use a propane quick disconnect at the back of the trailer that I can use for a Blackstone, Coleman stove or whatever else I want to hook up.
Originally I had the 2 stage FlameKing regulator that came with the heater hooked directly to the propane tank, feeding into a distribution block and then into the heater. That was all working fine. I then decided to plump in the line from the distribution block to the back of the trailer. I hooked up the Coleman stove and couldn't get enough flow to get a burner lit. I also tried a Mr Buddy heater which also didn't work. After some digging around I realized both the Mr Buddy and the Coleman stove have built in regulators so that wasn't going to work. I also now understand that the 2 stage Flameking regulator that came with the heater is a single appliance use device. I then decided to run propane straight from the tank to the distribution block. I have a line going from the distribution block and into the Flameking regulator then into the heater. Now I'm able to use the Coleman stove and Mr Buddy heater but I can't help but think this isn't the right way to do things.
Can anyone help me out with this? Is it OK to run directly from the tank into the distribution block? I really don't want to die in a huge fire LOL
