Properly rated hitch?
Singler3360
With the front water tank full and bikes mounted to the tongue of our Conqueror UEV-14 (USA), I need to get more rise out of the 2" hitch on the '14 F-150 Ecoboost FX4 with stock suspension. The trailer's wet weight is about 5,000 lbs. I measured about 6-8" of rise needed. Can I get by with a new stinger rated to 6,000 lbs. for $40 or do I need to buy a Bulletproof or equivalent rated for 10,000 lbs for a lot more money? If adjustable, it needs to accommodate the Cruisemaster D35 hitch pin. So far, I've only found the Bulletproof single tang adapter. Thanks!
M meadow build
