non_applicable
I'm in the process of selecting an e350 for a 4x4 conversion, either a 7.3 or a 6.0. I'm wondering what it takes to eliminate the manual operated stick from the floor and run a "push button" setup of some sort.
Yes, yes, yes, I know the manual operated transfer case is better =) But I need to eliminate the shiftier from the floor space there.
One option I've found is the Lovell 357 air actuated transfer case, but I'm new to 4wd, and to building vehicles, so I'm unsure what's required to run that transfer case instead of a NV271, Borg Warner, Atlas II, etc.
Thanks for helping a newbie out! I appreciate all input in figuring out my options.
Edit: As a side note - If the Lovell 357, or some other air actuated tcase is an option, I also figure I can use the same compressor to run some ARB lockers.
