WiscoinChicago
I have done a thousand searches and read every post on mud. I realize most people recommend not to do it, and go with ARB. However, seeing as an ARB with compressor is at least $1,000, and I can buy a whole axle with the diff lock off of car-part.com for as low as $400, the issues would need to be major.
From what I've read there are two ways to do this. 1. modify your existing axle housing to fit the elocker third member, and 2) swap in an axle from a 98-99.
For the first option, it appears most information I could find routes back to how its done on the 80s, where a chunk of the housing will need to be removed and two holes drilled and tapped. However, this is for an 80 series, and I read that the 100 series needs less modification. Can anyone verify this?
For the full axle swap, it appears the only difference is there are two brake lines instead of one. So brackets would need to be made for lines.
For everyone saying to go with ARB, I would prefer to go with a factory system and eliminate the extras needed with air lockers. I do not rock crawl, nor do I need instant lockup. I had an elocker on a 3rd gen 4runner and an Xterra, and had no issues with them.
Does anyone have any real world experience on doing this mod? It sounds like its done a lot more frequently on other Toyota 4x4s.
Thanks in advance.
Thanks in advance.
