Most repeaters are local in nature. They take your input signal and rebroadcast it, often from a high location that increases the range.
There are now linked systems that connect local repeaters together to increase footprint further. There is the WinSystem
http://www.winsystem.org/ which is a private network of reapeaters link over the internet. There are about 80 repeaters linked on this system across 14 states and Canada and Australia, many of them are 70cm. Mostly in CA, there are 5 repeaters in OR, and 2 in FL, but none in NY. When you key up any repeater in the system, you are heard on all of them.
If you need to talk to friends or relatives in a specific area not covered by one system, the better option would be IRLP
http://www.irlp.net/ for Internet Relay Linking Project. This system has repeaters all over the world that are connected to the system, but not all at once. You use your radio to access a repeater local to you, and connect to a repeater in another area. Then you have a direct connection from Bend OR to Buffalo NY, for instance. You can carry on your conversation, then disconnect when you are done. The website allows you to find repeaters anywhere. Find one local to you and key up to connect to one in your friend's local area. Each of you has to have the local repeater frequency, offset, and PL programmed in. The connection is simply keying in a code for the distant repeater on your number (DTMF) keypad. Then start talking.
These systems use ham radio at each end, with an internet connection in the middle. Another system mentioned is Echolink. This uses the internet, and requires hams at both ends, but connections can be made using repeaters as above, or direct through your computer connected to the internet.
