Hey Everyone,
This is a truly off-grid vehicle with great power, cooking, and water storage capability. The shorter wheel base allows you to go anywhere and make tight maneuvers.
Reduced Price - $90k
Please send me a message to get in touch!
Full set of pictures: Pictures
Summary:
With a robust solar/lithium system, heating system, independent off-grid A/C, indoor and outdoor kitchens, and true off-road suspension this van is incredibly well-suited for a lot of adventures. You could take this van up to the mountain for a ski day or on an overland adventure, it doesn't have a whole lot of limitations.
The Van:
The Camper:
Water, Heat ,Cooling:
Joey
Summary:
The Van:
- E350 Standard length
- 5.4L Triton V8 – 70k miles
- 2008 with a 2020 Passenger Van conversion
- Purchased with roughly 65,000 miles prior to the conversion.
- Total loaded weight is 8200 Pounds
- Total length bumper to bumper is 18FT
- Total height is 10’ 2”
- Fuel economy around 14mpg at 70 MPH
- GCWR of 13,000lbs.
- 3.73 Gear Differential (speedometer almost spot on)
- NV271 Heavy duty transfer case
- Dana 60 Front and rear Axle
- Timberline vans 6” coilover linked 4x4 kit
- Elka 12” travel bypass Stage 3 Coilovers – 500lb Eibach springs
- Bilstein 5100 Rear shocks with Timberline 12 pack rear leaf springs
- Van was originally converted to 4x4 in 2008 by Quad Van of Oregon and was upgraded to the Timberline Coilover kit during the 2021 conversion
- Buschwacker Fender flares
- 17in Method 305s in Bronze
- 33in Kenda Kleaver R/T
- Custom Front and rear Trac Bars
- Front Heavyduty swaybar with extended Links
The Camper:
- Custom R20 Morey Industries Fiberglass Hightop - Interior height – 6’ 2”
- 3m Thinsulate and Closed cell Foam complete insulation of floor, walls, and ceiling- Comfortable far below freezing temps and cools easily in Arizona heat.
- Complete cab and chassis vibration mat with Noico sound deadening
- Marine Vinyl insulated woven flooring
- Stainless steel Entry trim separating camper from driving cab
- Custom upholstered/insulated interior door and window trim
- All Custom lightweight Birch and Bamboo cabinetry
- Isotemp Cruise 49 black Marine 12v /120v fridge/freezer
- Thetford Triple Burner Propane Stainless Cooktop with glass top
- Thetford matching glass top Sink Unit
- Under bed and inside dinette latching storage compartments.
- Rear outdoor Zero Declination Shower Stall with Stainless marine hardware
- Toilet stall with Dometic Compact Cassette toilet
- Dinette Seating with Bamboo table with flush mount wireless phone chargers
- Modular aluminum and Birch bed platform. Bed Extends to a full ( 75x54 )
- 2 piece Temperpedic 3in memory foam mattress
- Custom made memory foam Dinette cushions and mattress wrapped in easy to clean marine vinyl
- Complete dimable LED lighting system with RGBW bed mood lighting flushed into aluminum trim accents on ceiling – with touchscreen controller
- Fresair 12v evaporative rooftop AC
- 5 total Interior 120v GFI Dual outlets with USB charging and wireless tabletop charging
- 12v USB charging stations
- Full pull-out rear kitchen / barbecue unit - Contains flip out propane cooktop and sink with infrared barbecue station.
- Custom door panels with first aid storage / tables / and cutting board
- AudioEngine A2 Bluetooth sound system
- Pedestal rotating passenger seat kit
- Aluminess front winch bumper
- Aluminess rear bumper with hitch receiver and storage
- Smittybuilt 15k front winch
- Aluminess Side mount roof / solar access ladder
- CARR offroad entry Steps
- Complete underside refresh – included media blast and full rubberized corrosion resistive coating.
- Pair of Baja Designs S2 floods on Hood Mounts
- Hella flush-mount bumper Pencil Beam Halogens
- Autarky Standard Solar Kit – AutarkyEv.com
- 300W Flush mount Rooftop Solar array
- Orion 30 Amp Alternator DC to DC charging while driving
- Victron 100/50 Bluetooth Charge controller
- Victron BMS with Shunt – Interior controller
- 2000w Victron compact Inverter Charger with Cerbo controller and GX50 touchscreen
- Midnight Solar Baby box with charge controller and inverter breakers.
- 200 Amp DC disconnect
- 30 Amp 120v interior accessible breaker panel containing all circuits both AC and DC in one easy to access and maintain panel.
- 300ah Ampertime Lithium Battery bank
- All mounted below rear dinette bench seats
- 35 Gallon Fresh water tank – SS marine inlets
- 8 Gallon Grey water tank – exterior Dump outlet
- Shurflo 12v Water pump
- Full Pex Plumbing
- Rear mounted Stainless Shower system – hydronic connected for instant hot showers.
- Rear mounted and enclosed 20lb Composite Propane tank – Only used for cooktops
- Main Gasoline tank connected Eberspacher Ds5 Hydronic system - Instant hot water heat exchanger and Kalori thermostatically controlled in cab water to air heat exchanger.
- Eberspacher easy start pro controller
- Rear bumper mounted all aluminum hydronic tank for easy service
- All plumbing and tanks are mounted within the insulated interior and will not freeze while camper is heated
- Fresair 12v DC Evaporative cooler with separate 8 gallon water tank.
- Custom Gold reflective heat shields for every window in the camper
Joey
