As far as the recalled balljoints go.. dodge recalled only the uppers. Dodge originally put crappy "sealed for life joints" on the 2wd/4wd dakotas/durangos (which are riveted on the upper control arm) Dodge did this for cost reduction and "no maintance", hell, I bet the engineers bragged about it! It came back to bite them in the ***!
When the ball joints were replaced as part of the recall, they replaced them with equivalent bolt-on GREASEABLE joints.
Dodge did the right thing and replaced all of them with greasable one's for free, under the recall!
If the replacement balljoints go un-greased THEY WILL FAIL! The cast section of stock upper ball joint is kind of small for such a large taper size, I run an aftermarket control arm that uses a chevy2500 ball joint (with the same taper as stock) that's super beefy, but that required extensive modification on my part!(and is only available for 2wd's)
Stock is located far left, chevy 2500 joint middle (90's model) (one i'am currently using) , chevy 1500 joint far right (70's model).
As long as you take care of your replacement ball joints and keep them well greased and happy, you wont have any problems. All the stock upper and lower balljoints/ inner and outer tie-rods need to be replaced ASAP as they cant be greased and WILL FAIL! Look for replacement greaseable parts with zerk fittings, Raybestos makes great suspension parts that make moog's look like crap IMHO
You can get raybestos parts locally under napa as the NAPA rebadged "preium quality" line or under rock-auto as raybestos (rockauto is wayyy cheaper then napa)
The bumper company you speak of is kennesaw correct? (
http://www.kenmtn.com/)
They have horrible customer service and a 2-6 month turn around time (depending on their mood). The prices are extremely reasonable, I've heard an equally good amount of good things and and bad things about them, based on numerous reviews I don't know what to think of the company, so I decided to build my own.
I hear the bumper quality is good, but you have to line up and drill your own mounting holes through 1/4" steel.
For people looking into dakota's and durango's:
As far as power goes, get the 4.7L!! you wont be sorry! It's an excellent engine chain driven SOHC and is backed by an equally capable tranny and that is followed by an overbuilt bulletproof rear-end!
Replace all fluids, have a good mechanic check over EVERYTHING.
Replace all joints/bushings/wheel bearings and you wont have anything to worry about!
Keep the tire size under 32"
Wheel hard in 2wd, keep it out of 4wd OFF-ROAD until necessary.
What I like about the Dakota:
It's a beautiful truck, low and wide with great fender lines reminiscent of the original POWER WAGON, copied over from the RAM "big rig" styling line. This is the only pickup that doesn't look like a "BOX" in my eyes, it's downright sexy!
The Dakota is the only available mid-size pickup with a V8, which makes it more "************" then anything in my book, nothing says American like a gas guzzling, good sounding torque loving impractical V8!
The drive train is well thought out for an American vehicle, minus the D35 front diff on 4x4's.
Did I mention V8?:bike_rider:
X3 on that v8:smiley_drive:
What I dislike about the dakota.
No aftermarket support, this thing is not a jeep or toyota!
Dont expect to take it off the content, try finding dodge parts in South America!
2wd's are designed for the pavement only, 4x4's are designed for mild offroading and snowy/icy conditions.
Many cost cutting measures taken to make the vehicle cheap to manufacture and supposedly "maintenance free":Wow1:
Was not engineered to go 150+K miles.
