I’ve been looking for the same for months without any success - I guess it’s just too early still.
That said, I discovered I can charge (charge only, not power in use - so battery power still decreases when plugged in) both my newer MacBook Pro and iPad Pro using a USB-C to USB-C cable plugged in to some PowerWerx dual USB high amp plugs. It’s enough to charge both overnight.
What about one of these
Chargeit! Mini 75W Dual Port USB-A & USB-C PD Charger w/ PPS & QC4.0 Support
Chargeit! Mini 75W Dual Port USB-A & USB-C PD Charger w/ PPS & QC4.0 Supportwww.usbgear.com
So there's something ..
FYI - you can get the board only- ( no enclosure) if you want for even less money .
USB-C High Power Car Charger Board 60W PCB Only Cypress CCG3PA PPS Support
USB-C High Power Car Charger Board 60W PCB Only Cypress CCG3PA PPS Supportwww.usbgear.com
I also asked about a 90W version. They said it will be ~1year,,..
@hour
What Cells did you use for that ammo can? I'm looking at the Headway 38120 cells. I have enough 18650's left over from a few projects and wanting to order more cells in bulk.
@hour check this out. Looks like there is a PD charging circuit out there somewhere for powerbanks.![]()
What are the odds these "12/24v" USB car chargers function all the way throughout that voltage range, ensuring that they'd be happy operating at 16.8v? I'd probably omit the normal 12v cigarette lighter from this build for simplicity, not having to add another component to ensure typical 12v gizmos don't fry when plugged in.
Fairly high, I've rolled out my fair share of circuit boards (mostly for 4S Lipo Packs funny enough) and the vast majority of voltage regulators for "12v" sources are capable of a pretty wide range input.. if they say 12/24 I'd bet the components are rated a much wider range than that.. for example: https://www.mouser.com/ProductDetail/Texas-Instruments/LM340S-50-NOPB?qs=X1J7HmVL2ZEJihwXwjTuRQ==
It would be more complicated to engineer a voltage sensing circuit and have multiple input regulation paths than it would be to just slap regulators on that can take a wide input for both 12/24
Just remember, an inverter uses power when on and not in use. So if the vehicle is off/ key in the on position and not running, and you are charging, it will drain a battery quicker.
To each their own. We like to show up and not turn the key until we are leaving.
