question about bent Wilson 1000 antenna
oddball
I have a Wilson 1000 CB antenna thats bent at a 40 degree angle. If I'm able to bend it back without snapping it, does anyone know if it will effect reception, SWRs, etc?
rusty_tlc
It will work fine. You might need to check the SWR if you have to remove it from the base to straighten it. Or use a sharpie to mark where it sits in the base before you remove it.
Supreet.dhaliwal
