czenkov
2004 Tacoma (POSER) pic attached. I priced out some things at the local 4 wheel drive parts. I have some questions. This will be expedition style upgrade. I do not want a ton of lift, merely something that will support the weight of my plans. My plans include ARB front winch mount bumper with minimum 9000 Warn. I currently have a topper on the back and plan on building shelf system for rear. I will likely install custom rear bumper with swing-away spare tire and gas can carrier but that will come later. Also the Topper may be removed in favor of a Roll-Top-Cover with rack and RTT also later.
They recommended OME front then helper spring in rear with air bags. I want a suspension that can handle the weight in the front and back. Here is the parts list. If it makes sense to anyone can you tell me if this will be appropriate in regard to what I plan to do?
Parts list.
ARB OME881 OME881OME 96> 4RNR Front
ARB N91S N91S Coil Over Shoc
ARB CS046RA CS046RA Tacoma To 0
ARB N85 N85 Shock Multi App
ARB OMESB89 OMESB89 Bush For OE
ARB FK21 FK21 Tacoma Exhaust
AIR 59537 Ride Control Air Sp
ARB 3423020 97-04 Tacoma Winch
WAR 26502 M8000 Self recovery (thinking I should probably go w/M9000?)
ARB front Bumper with winch capability
M8000 (M9000) Warn Winch
OME front suspension
Helper springs and air bags rear
Parts list.
