ashooter
I've got a thread going on this over at 'Mud, but thought I'd run it by you guys as well...
Background: I'm getting ready to buy an ARB front bumper and an Iron Pig rear and that got me thinking about bumping up my suspension with some trim packers to compensate a little for the added weight, since I'm running "low lift" springs and don't have a lot of "extra" room with 33+ inch tires. My main concern was whether or not I would need to also add caster correction bushings with this minimal lift, but after doing some measurements I've got a couple of other concerns.
I just did some measurements and it looks like most of my problem is left-leaning body...
First is current measurement straight down from fender edge to tire tread, then trim packer I plan to add, then the expected result.
LF: 4 3/8" + 25mm = 5.36"
RF: 5" + 10mm = 5.39"
LR: 5" + 15mm = 5.59"
RR: 5 5/8" + 0mm = 5.62"
Any thoughts??? Is this body lean a normal thing meant to compensate for the road crown when going down the highway?
The truck drives fine and tracks straight as-is, so I'm a little leary about fixing it if it ain't broke, but it just looks funny to me when sitting on flat ground.
