Questions For The OME Gurus Out There...
vengeful
I know there are a BUNCH of you running Old Man Emu coils out there, and I've been looking very heavily into picking up a set to run on the back of my Pathfinder when I re-do my suspension. I want about 3.75-4.25" of total lift over stock, as this will allow me to run a 255/85R16 tire to get a full 11" of clearance under my rear diff, and not put too much stress on the drivetrain.
I was looking around at Land Cruiser coils, thinking that if there is a 3" coil for the Cruisers that it would give me the lift I need in my lighter Pathfinder. I found what would probably be the ideal coil for the application, but I need to get some measurements to be sure. If anyone happens to have the OME863s on their truck, and could measure the wire diameter to 0.001" (calipers or micrometer), outer & inner diameters to 0.01" (a good machinists or engineers scale should get you close enough) and the total number of coils (including end coils), and free length to 0.1" (even a cheap ruler can give you this, lol), it would be MUCH appreciated. :wavey:
I know this is probably asking a lot, but there seem to be some pretty brainy people on this forum, so you can understand the need for precision in these measurements. At ~$150/pair for OME LC coils, I want to be absolutely sure that these will suit my needs. I'm 99.5% sure that the diameters will not match up with the Pathfinders, however, I'm not opposed to welding on some Land Cruiser spring perches to make them work if they're perfect. :)
Thanks in advance.
AC doesn't have anything.
I've had the AC lift on my Pathy since 2002. I need something much heavier duty.
I really think you are going to have to go custom from Valley Spring Works. I've never heard of anything more heavy duty than the AC springs - although Jaos may still make something.
That's awesome, thanks Cruiser! Just what I needed. If someone could quickly measure the inner diameter of the 80 and 100 series springs for me, that would be awesome.
I'm not necessarily looking to run Nissan coils for this application, and I'd rather not have to wait for custom coils to be made.
No worries :cool:
80 & 100 rears are the same... 80 fronts have a smaller diameter. I'll grab some measurements for you this afternoon hopefully.
What about the Ford 150 front coils or Jeep ZJ coils? I know that was a very popular mod for a while with the WD21, but if memory serves they did have a tendency to sag after a while.
empireoverlandza
