ExpoGeorgia
Is it possible to swap in a 6bt (12v) Cummins motor and an NV4500 5 speed into a FZJ80 with a 4 inch lift? No body lift is needed correct?
The only fitment issue that I know about with a 4" lift is the clearance of the oil pan over the front axle. Several guys have modified their pans to clear the pan with less lift. The engine is 36" tall... thats the issue.
Here's a 6bt swap from 'mud
http://forum.ih8mud.com/hardcore-corner/84611-cummins-6bt-install-fzj80.html
There were a bunch of 4bt rigs that were sold over the last year or two. It suggests to me that perhaps people weren't real happy with the 4bt swap. I would try to hunt down some of these guys that did the swap and get an honest opinion before investing the time and money.
You can indeed. It is very (excessively) loud, not in a nice way, and shaky. The marine 6BT has a flat pan- I will take pics of our new pair and measure...
Thanks for the reply! From my thoughts the 4bt doesn't offer the power needed to haul an FJ80 loaded with gear
I'd rather have the Toyota diesel installed however you have to look at the avalibility of parts that are both cheap and readily avalible.Plus as I've said I already have a 6bt for a swap. But as I said with the 6bt and 4bt, I know the 4bt can carry the weight of a fully loaded FJ80 with trailer, but how would it do in higher elevations?Well, thats not true. As much as I dont like these swaps, there is more than enough power to pull an 80 around. To say that a loaded 80 is heavier than the step/ bread vans that these motors came out of is dumb. People sell the 4BTs all the time because they arent what they thought they would be. They are loud. They do vibrate more than anything else. They are very heavy requiring a stiff spring rate and they are super tall meaning that you will have to lift 4" to make clearance. I thought about it but after consulting with Proffits (if anyone knows anything about these swaps, its them), I decided a factory diesel was a better option. I would rather a Toyota diesel in a Toyota than a heavy diesel like this one. Quieter, smoother, meant to be there and lighter. I think the only advantage to the Cummins is that you can pick one up for cheaper than a Toyota set up. Thats it though.
6BT P7100 pump and the nv 4500. Don't look back, just build it. The p7100 pump 12 valve is still the best diesel on the market, just take note to what all the sled pullers are using for a foundation. From all the reading on mud it seems about 4" will put you right. Good luck.
I've got a VE pump as the motor came from a stock 1st gen, but I'm thinking of doing a P pump convertion. I don't have much of a need for a powerhorse (I've got the 1st gen for that lol), I'm just looking to get more fuel mileage and reliability.
