Ram Cummins - Auxiliary Fuel Port
chiung
Does anyone have experience drawing diesel from this port? .pdf is for C&C models but I wonder if the port is also on the non C&C 3500 (2016) I would like to supply fuel to a diesel heater.
from the .pdf - "An auxillary fuel tap is provided on gas and diesel fuel tanks to provide fuel for
secondary power systems. This is located on top of the fuel pump module and is sealed
with a connector. It is designed with barbed end to accept a hose and clamp. This system
will not drain the vehicle fuel completely. There will be sufficient fuel to drive back
from the worksite."
Thanks
Wilbah
Looks like it is on the Chassis Cab only (but w/o the pdf for non Chassis Cabs tough to tell?). Check online replacement parts and see if the part numbers are the same for both Chassis Cab and "other"....if part # the same its prob included in both. But even if not might be an easy replacement to get the upfit/Chassis Cab version and replace the stock one so you can do it.
jacob_lashell
