Overlanding 4WD
2010 L322 Range Rover Autobiography Black. 135K Miles, I’m the 3rd owner, came with FSH, and it’s a beaut.
Been in for some service items, CV boots, a leaking turbo pipe, worn ball joint, full service, get the rusty and rotten side steps off, along with the front integrated mud flaps. The wheels have been replaced with Black L405 1065 style, with Cooper Discoverer AT 275/55/20’s, which may or may not get switched out to 18” in the future, will see how it performs on 20’s.
I‘ve installed an“Easy lift suspension module, 10 min job, which gives me 5 extra ride heights, the added factory raised heights, changed via the Gap Tool, raises to 4” in extend mode, all controlled via an app, one cool function, it has an auto level function, which will help when the RTT is on for trips.
Few things that need doing, removing the cheap stick on wind deflectors, ??♂️ I know, they are terrible, clean the leather interior, yes it has the headliner hand stitched in leather, it’s in really good condition but needs a good clean and the leather fed. All incandescent bulbs have been replaced with LED’s, and a new set of front mud flaps, without the side step cut out. Install the full rear dog guard / cage, and start to plan out how the fridge slide, dual ARB compressor and Redarc BMS Manager 30 will fit in the rear loadspace. Then it‘s on to deblingIing it, remove the plastic chrome and silver trim items, and replace said items with black versions, easy to do. Before and after attached.
Cheers
I’ll be documenting this build on YouTube, as well as here. The plan is to take a 2 week trip to the Spanish Pyrenees in Jan, already booked, so subscribe and watch the build
You tube channel
Cheers
You tube channel
