Right now it has stock gears......it is a struggle going up the mountains here
My future plans would be a hemi but that most likely is 2-5 years down the road
I am going to stick with 35s for the considerable future they're plenty tall for the trails I go on and this rig is my daily driver
I agree I think that the engine runs better at higher rpms and it will prevent all those downshifts it has right now
Hate to say it, but the 3.8 will struggle regardless of what you do...mtns or otherwise.
The JK is a heavy platform and modern engines systems have changed our perception of acceptable/need. The JK platform started it's life as an under powered platform (as compared to other similar sized vehicles at the time). The auto in the 07-11s with its wide gearing and sub-optimal shift programing - makes it worse.
The gearing will help get the motor to operate in a better power band. Follow my recs above - it will restore/move the rpm/mph powerband to a more appropriate point.
There are people that claim the 4.0 is better - it isn't. It's worse. The tires the 4.0 motor spun and Jeeps it powered, were lighter/smaller/less surface area. Is it more reliable? Probably b/c it is simpler.
The 3.6 is a better motor only in that it has more power with a slightly different power curve. More reliable? Maybe...maybe not (I'd venture to say it isn't, the 3.8 is a simpler motor).
The 3.8 JK/JKU Jeeps require a slower pace/slower highway speed expectation...the gears will make a big difference and restore proper operation, but will not never be a more powerful platform.
I say all of the above to help align expectations - I sometimes have to remind myself of the above...and ask, is it worth the cost/time to get rid of my 07 and all its mods/custom built equipment. The answer is usually, 'nope at the moment, it does what I need just fine, just a little slower. I can use the ten of thousands on other, better ways.' And then I smile as I pop it into 4wd, get onto the trail ...and then arrive at camp for the night....the thousands I've saved lets me get out sooner, longer, and spend more time with my son, family, or friends...
Sent from my Pixel 4a using Tapatalk
