Real time help CONQUEROR wiring
I know I have read on here some one gave the wire colors for the lights but My compact gets in tomorrow and my dads picking it up. He has to do a 2 hour drive after pick up but of course his truck only has the standard 4pin plug. I figure i can give him the colors and he can hack it right there just to get home. some one help out?
thanks
mike
mtnbike28
what I did
This is what I did.
I cut open the trailer end plug and chased down what each wire did, matched them to the 4 wire plug for my truck.
On the trailer: On the truck 4 wire plug
white wire (right blinker) green wire
Blue wire (brake) left unplugged (see below)
Red wire (running lights) brown wire
there is a weird jumper inside the plug
gray wire (left blinker) yellow
black wire white wire
There were a couple of wires I had to put together on the trailer so bring larger terminals or whatever wire supplies needed too...
The only other change was in the back, using a small screw driver I switched the spades inside the factory plug going to the red lights in the rear (un-did the blue and replaced with the gray and white wire, one each side)
this does not use the yellow lenses at all. I plan to replace them with red and tap into the rear side running light for power.
To test, I ran jumpers from the trailer's battery... just remember to test the blinkers, you have to touch/untouch/touch/etc. the flasher part is in the truck. This is on a Toyota, but I think the 4 wire YBGW is standard.
As a warning, you have to lay on your back for a while to do the rear... bring a piece of cardboard or mat to keep from keeping dirty. As a back-up plan, he could spend the $25 and buy a cheap set of "add a light" kit. The ones I got had a tongue to stick in a tailgate or trunk and fit nicely in the bottom of the tailgate for the fridge.
hth
Dendy Jarrett
Expedition Portal Admin
Staff member
Honestly, I can send you a wiring schematic that I got from the South African Expedition site, but It is probably too complicated to 'hack'.
If I were in your shoes, I would pick up a set of magnetic lights from your local auto parts and run those for the short trip home.
Shoot me an e-mail at nashvillerover@comcast.net and I will send you what I got from the SA forums.
Thanks
Dendy
Thanks
Dendy
sounds good, ill have him pick up a set so he doesnt have to mess with it.
Thanks fellas
mike
cybercat
Thank you for your wiring brake down. The trailer side plug diagram on the SA forum has different colored wires.
This is what I did.
hth
dieselandmud
Stop by a Tractor Supply Co., Northern Tools or autoparts store and pickup some magnetic lights with a four pin plug. It should have a 12-16 ft of cord with it. Wrap the extra wiring around the frame. Never sell it, it is a good backup. It has saved my tall many times.
Houie
