geniuskidzz
Dear All,
I have 2004 Ford Everest/Endevaour (the wagon based on old Ranger- Not the T6 - and not the NA ranger). It got 2.5 old diesel (non commonrail) with 4 speed automatic and 2WD (in my country - Indonesia, the 4WD 2nd hand mostly subject to abuse and either have high 2nd price or really bad rust underneath)
I bought this with modification donor car in mind (only need the frame suspension body etc.. the engine, transmission, and drivetrain will go in favor of 4WD 5 speed ford/mazda 3.0 commonrail engine)
but its on later stage. Right now, i am looking to replace the rear leaf spring.
The terrain it will go with are :
1. high speed gravel
2. Lots of plotholes ( so looking for friendly suspension)
3. maybe 10-20 % Muds, river crossing, and other things that need 4x4 with locker
No rock crawling, no things that need long articulation
I am looking for a comfortable solution for long range driving ( there are some days that i spend driving 2-3 days straight)
I have searched the forum (and google) for leaf spring conversion, and have found below solution.
1. 3 Link coil conversion
2. 4 link coil conversion - parallel - with panhard rod
3. 4 link coil conversion - triangulated
4. Watts link
As far as i know, 1 and 3 need welding on the chassis for the middle link, so since im looking for bolt on solution (its kinda hard to find good welder in my area, but its easier to send CAD design to some small manufacturer and have them made it, all cut and welded by machine), i probably will go with either 2 and 4
right now im geared toward 4. Theres some company in US that made similar conversion for race track (Mustang? i believe it was called Fays). Its reverse watts link where the middle link are on the chassis, and the side rod are mounted on both side of rear axle. If i limit the middle travel, the axle will stay on linear articulation (without touching the curving end of watts link)
if i choose 2, theres thailand company who made the kit available (4x4 exo) for USD 1600.
I have to made myself if i choose 4.
I will either use airbags spring or regular spring - gas/oil performance spring (fox/kayaba probably )
My question, do i miss something (other kind of solution? the risk of using bolt-on system? etc?)?
Thank you.
*edit
no, it wont run street HT tyres like in picture. it was using MT tyre - GT Savero. I changed it to HT since last few month i couldnt spend time offroading at all, and travelling strictly on good roads/packed gravel.
I will use AT tyre again after the modification to 4x4 done.
4. Watts link
Thank you.
*edit
