Rear locker air pump location?
grandpa
Where is the air pump for the rear locker located in a 1999 Montero? The parts guy is checking to see if he has one.
Thanks.
Justice R
yes, If i remember right its on the pasenger side cubby under the rear seat. there's a black metal bracket that holds it in so its kinda hard to see.
MrGalantguy
Mitsubishi Loyalist
Thanks.
It's under the rear passenger seat in the cubby hole hidden behind a black bracket. Best way to get to it is remove the rear passenger seat as the 10mm bolts are under the carpet and removing the seat allows you to lift the carpet to access the 3 10mm bolts.
jeep-N-montero
I'm pretty sure that in the 4+ YEARS since this was posted he has figured out where it is....
jacob_lashell
