bruzer1123
Okay,
Gotta love the New England trucks. Went out to my truck (1993) several months ago and noticed a flat on one of the tires. So, took the tire off and then tried to get the spare down. No luck & I sheared off a portion of the nut holding the spare tire in place. Put the flat tire back on, backed up to an electrical outlet and cut my spare tire down. The chain release thing is all rusty and crap.
So, my plan is to remove the chain spare tire holder and fab something up. My thought was to take a big bolt (3/4") and tack weld 1/8" stock to the end. I would drill a hole through my rear cross-member and then tack the flat stock to the cross-member. Shove the spare into place and have a 8" diameter plate (1/4") as a giant washer and then a nut with welded pipe to use as a handle. Does anyone have thoughts on this? Do you think the stock thickness is enough? To much? I realize it will be hard to put the tire up there, but I have used a similar fix on an older truck. My plan would also be to put a second nut on or a trailer hitch pin to use as a safety. Also likely to have a small cable to keep the tire in place in case the giant bolt fails.
Pretty much just a fix for now until I can fab up a bumber (again) that can accommodate a swinging spare tire. So input would be appreciated.
