Rear View camera for your camper
brian90744
American Trekker
I installed a 12V wireless (rear view)back-up camera system. The 3” monitor just plugs in to the 12 volt outlet in the truck. The camera had a 8 ft cable to connect to the back up lights 2 wires. I temp hooked up the 2 wires (blk & rd) to the battery= turned the monitor on , GREAT a Back-up system works. Next I cut the camera cable that down to about 2 ft long and noticed a metal thing about 12” from the camera, then I slit the 2 wire harness cover open ( easy) and found the metal tube was the wireless antenna. Found a place on the back of my camper to mount the camera. Looked inside my camper to locate a 12v power line, found under the rear seat, rear pouch light wires close the camera hole I drilled to mount camera. Join the positive and neg wires to the pouch light wires. Works . It doesn't have to be connected to the brake lights to work, just any 12v line. see pictures.
I can also plug the monitor inside my camper to see who’s outside my unit. Driving it’s like having a rear view mirror in the cab. I can monitor my 60" wide M416 trailer on the highway while driving for any problem such as sway & bounce and it help when backing up. If you tow a trailer this is a good addition to your camper, NOTE: All 2016 Cars will come with Rear View Cameras.
chet6.7
Nice,I may have to do something similar since I lost my tailgate cam when I put an ARE DCU with rear doors on the truck.I miss that cam in the rear view mirror.
cchoc
Wilderness Photographer
I just moved the camera from my Tacoma tailgate to the rear bumper. Would probably be easy enough to put it on my FWC Eagle but I'll be adding an Aluminess read bumper w/spare mount and box which would block it.
chet6.7
^^Thanks,I may give that a try when I get an aftermarket bumper,I will ask for an extra hole in it when ordering.
