In "general" terms, "rule of thumb" etc. I would go with 1.5X. So, if you have an 8000# winch, you'd rate at 12,000 for dynamic. But that's a single line pull on the first wrap on the drum (etc... ) Now, double line pull. 16,000#, at half the line speed... OR last wrap on the drum, which is less than winch rating... Another way of looking at it is the (fully laden) weight of the vehicle X2 (or at least 1.5); however, if you recover another vehicle of unknown weight, you want the winch to stall BEFORE the rigging fails.
So, if you are not "stalling" your winch, you are not running at its maximum rated capacity (for the coil layer you are using at that time). I have stalled my Husky 10 on a double block first wrap on the drum (that's about 40,000# pull) and broke my plasma line doing it (which was not surprising as it was an older line anyway). None of my rigging failed, just the plasma line. And since the winch was stalled, I wasn't capable of pulling any "harder" than that...
Bottom line, in my case at least, my rigging is suitable for my winching activities.
Snatch straps are another story. F=MV (Force equals mass times velocity) So, the vehicle mass multiplied by it's velocity equals the force it exerts. Move the same truck (a little bit) faster, the force goes up significantly. Something to keep in mind, and also why so many "recovery" points end up being ripped off vehicles when they are recovered (or trying to be recovered).
I'm sure there are guys much smarter than I am on this subject (Physics degreed individuals for example) who can provide a more comprehensive dissertation, but this is the "Cliff's notes" version.
