PLEASE do not waste my time if you are not serious. This is a large slide-in truck camper that needs a heavy duty truck with an eight foot bed. Ideally a F350 or heavier. Dual rear wheel truck the best option have best payload.
For sale if my Bigfoot 2500 series 10.6 with lots of work done to allow off-grid use without needing to use camp grounds on trips if you don’t want to. This will be the best Bigfoot you will find guaranteed.
Highlights:
This truck has a dry bath (separate toilet and shower) so no wet toilet after shower and can be used simultaneously which is great for a practicality.
50 gallon fresh water tank
9 cubit foot fridge freezer which runs on propane or mains power.
Already dewinterized and water system sanitized.
Water pump, water heater, furnace all working perfectly.
Off grid system installed costing several thousand just for the equipment, not including many hours to install.
Electrical:
4x100 (400 Ah total) lithium iron phosphate batteries in an insulated box where generator would normally reside.
400W of solar with 40Amp Renogy solar charge controller. Bluetooth monitoring of system setup.
Main disconnect switch with Victron Bluetooth shunt to monitor batteries’ state of charge.
Victron Lynx distributor to centralize wiring and fusing of all circuits
3000W inverter with remote switch so microwave and all mains power outlets inside and outside camper powered (120V power for hair driers etc like being at home)
Installed but not yet wired switch panel with power output via USB and cigarette lighter
All internal lights updated with LED that are either motion sensitive (kitchen) or dimmable with ability to switch between warm and cool colours
Reading lights next to cabover bed updated to Flexy, dimmable LEDs with USB charging port on each.
Interior
Entire camper including walls, cupboard doors, fridge etc all sprayed with airless paint sprayer for flawless finish at great expense as took many hours of prep. Paint used scrubbable to make cleaning easier.
All carpets replaced with new carpet
Most flooring now vinyl planks in main walkway and bathroom
Dining area seating reupholstered including side panels
All old valences with blinds replaced with self retracting blinds or custom-made curtains
Known issues: Air conditioner needs replacing
Please feel free to ask Questions. Will consider sensible offers. Asking $31k CAD
Highlights:
Electrical:
Interior
