Replacement Jackery cables
riffman12
So I bought a Jackery Explorer 240 used, but the seller wanted to keep the charging cables for another unit he had (gave me a discount due to not getting cables with it)
I reached out to Jackery to see if they sell cables separately, but I think they're working under partial capacity at the moment so it's pretty slow hearing back.
Did some searching on Amazon but can't find a definitive cable that works with the unit.
Does anyone know a third party wall charger and car charger that will work with the Jackery 240? Looking to buy both cables.
john61ct
It is rare for any wiring harness to be difficult to DIY.
Hardest part for noobs is identifying the right terminology for the terminations needed.
If an expensive specialist tool / crimper is required, there are ways to solve for that
but the supplies themselves are rarely that pricey.
john61ct
Yes some vendors purposefully uses obscure non standard terminators to lock you into buying their proprietary cabling.
Their products should be avoided, unless they have tremendous value or unique advantages
that overcome such anti-customer business practices.
In which case you just have to budget in that extra cost.
jacob_lashell
