Retro Window...good idea?
bkbroiler00
I'm thinking of adding a classic bubble windows on the passenger side rear where my bed will be. What do you guys think? I know the van has a contour on the side, and I doubt the window has one to match. Will I be opening up a can of worms and have leakage issues down the line, or is there a good gasket/lots of silicone that can make keep it sealed?
here's one of the windows i'm considering... http://www.ebay.com/itm/70s-Van-Windows-Porthole-Bubble-Diamond-Chevy-Ford-Dodge-Plexi-/321855147255
is there another option i should look into for the throwback look?
thanks for the input! :smiley_drive:
Bikersmurf
I'm sure you could seal it in with Sika Flex... If you put in a small window, you can always put cut a larger hole for a replacement window (should the need arise).
crostopher
