eblau
Originally posted this with a ton of aftermarket/ overlandy stuff but I am
now reposting this basically stock aside from the OME lift, 285s and dual battery setup.
Currently has about 254k on it but engine has approx 170k on it. Original engine had an odd timing chain tensioner failure.
Recent maintenance includes both front CV axles, lower ball joints, tie rods, 285/70/17 Falkens, cam tab eliminators, alignment, front/ rear differential/ transfer case fluid changed, new radiator, new trans cooler, new water pump/ thermostat, all four cats replaced around 20k miles ago.
Other work:
Aftermarket Old Man Emu lift
Windows tinted 20%
Alpine head unit with Sirius XM
Replaced factory subwoofer
*Sunroof not currently working, this is a know problem with these 4th gen 4runners
Everything else works, windows, rear window, seat heaters, auto climate control, heated mirrors, 4WD engages properly, etc. Asking $8k or best offer, no trades.
Other work:
Windows tinted 20%
