Rim dimensions
Amesz00
Hi guys, those with 16 or 17" singles, can I get a quick measurement of the inside diameter? Somewhere around the middle of the wheel, and inside any valves etc. Basically the largest dia that will fit freely.
Cheers all.
Alan's Alloys. From mounting surface :-up 55mm is 350mm Dia. - up 120mm is 350 Dia so parallel. Slight step out in diameter then tapered to 390mm at bead at 210mm out from mounting surface.
Dan.
5mouse
