I have the Quick Pitch shower for many years. In comparing the two the quick pitch has longer side panels and they are height adjustable. I think this gives much more mounting flexibility on vehicle mounting. If you have to mount it higher you can lower the panels closer to the ground. The RLD has a fixed distance from the mount to the ground so if you have to mount higher then the curtain will be higher from the ground. The overall length of the quickpitch curtain is longer. A 6'2" person in the quick pitch won't have his head above the top in my setup but from the RLD video the guy's head is partially above the curtain. The RLD is a nice design but I think the curtain to ground length adjustability of the quickpitch is better. I've moved mine from my older rig to my new one and a simple strap adjustment placed the quickpitch curtain at the desired height.
Sent from my SM-N975U using Tapatalk
