After building a lx450 + chinook I have decided to sell my expedition trailer. Located in AZ. In its previous life this trailer housed an assortment of heavy duty tools for the military. It was built to last a lifetime and will outlast most trailers currently being offered. All steel construction with heavy duty joints and hardware. Ample storage, access and organization for all gear. This unit is excellent for a base camp type trailer platform. It holds 40 gallons of water and propane for longterm use. I will include a fixed mount horizontal propane tank (new) which I intended to mount above the gas/water cans. The rear has double full height barn doors along with a spinning drum for coiled rope or cord. Afixed to the rear doors are 3 aluminum folding tables. Adds a lot of table space to camp. The non cook side could be easily converted to a sleep platform or if you need a single space you can sleep right in the trailer:Wow1:.
Has the following:
40 gallon water tank
12V pump
fuse block and relay for pump
Ecotemp water heater
4 pin trailer harness
park brake
hydraulic brake- actuated by Pintle hook
roof rack
scepter can rack on front - can store 5 cans
two sinks and pull out faucet
external hose attachement and easy access hose storage
2 burner stove- welded to body
internal kitchen rack storage- steel
support struts for opening upper doors- can be used with locks
Will sell with a horizontal propane tank Manchester (new) 15lb.
hanging storage bags
Interior carpet
Will also include:
solar panel dm solar 158 W
propane outdoor heater
Needs- new seal on roof hinge (long rubber strip)
wiring to onboard battery- the fuse block and wiring for pump are fine I just disconnected the wiring to the battery a few years back and haven't used the trailer so never reinstalled. Its an easy fix.
repair one plumbing pipe- for some reason the last time I tested the pump I saw that one of the pipes had split- should take a few short pieces of PVC and two elbows and all good.
Could use some paint...
I can make all repairs as above but you would have to wait on delivery as I travel back and forth to the East Coast.
The trailer has had 1 or 2 trips since originally finished and has been sitting for 2 or 3 years. Unfortunately I have project issues and decided I needed a popup expedition RV so I haven't had the chance to really use this awesome trailer.
pm with questions. Asking $4600.00 offers welcome.
Has the following:
12V pump
park brake
roof rack
Interior carpet
Will also include:
