Got my shiny new Front Runner roof rack all built and ready to go, went to put the tracks on tonight and that's where the install progress stopped.
About six months ago the roof glass developed a crack and we needed to have it replaced. We took it to a local auto glass shop and their turn around time and price was far better than Land Rover Dallas, the dealer quoted $2,600 the glass shop said $1,400 using genuine Land Rover glass.
We dropped it off on a work day and by the end of work my wife was able to pick it up. We were happy, the wallet was a little lighter but better than the dealer and upon inspection it had the Pilkington Land Rover logo on the glass. All the black plastic caps were in the tracks and things looked great. I should mention we use the factory roof rails for our Thule Sonic box and have for quite a few trips.
Fast forward to tonight, I start the install process for the Front Runner rack which requires the removal of the factory roof tracks, passenger side came off easy as pie. Started at the rear of the drivers side, fine, middle, fine, front "oh, hey, there is a little black Philips screw, no big deal" walked over to the toolbox and grabbed a Philips and backed it out. I figured when looking at it they must have lost the fastener that came with it and found another one with the correct thread pitch and used that. WRONG! I then tried to simply pick up the factory track as I had on the passenger side, it wouldn't come up, checked the screws at the front, middle, back, all loose, hmm, gave it a tug and realized it was stuck at the front, (insert sinking feeling here) Pulled again and it came loose, noticed there was a lot of black silicone through the track and onto the factory mounting post. Upon further inspection the glass shop broke off the factory torx bolt in the hole and drilled it out and then proceeded to use a small self tapping screw in its place.
Solution? Tried a screw extractor, no joy, drilled and tapped the location, SLOWLY. Saying I was paranoid about drilling through the roof of the truck is an understatement. Here's the facts:
You can drill 16.4mm down into the factory mounting post (as far as I needed to go based on new fastener length and hardware to be installed)
Threads are M6x1.00
It was well after their hours of operation when I began my little adventure, I'm unsure of what to do, any thoughts? I've never seen this type of carelessness before, and, frankly, am at a loss. I fixed my truck and I am thankful for that, but I want to communicate to the shop in a way that might help them perform a higher quality of work in the future.
Threads are M6x1.00
![k6SQVVO.jpg](http://i.imgur.com/k6SQVVO.jpg)
![jOBIcW2.jpg](http://i.imgur.com/jOBIcW2.jpg)
![5JW5A1H.jpg](http://i.imgur.com/5JW5A1H.jpg)
