RoverDude
SALE PENDING
This is a used pre production unit called The Adventurer offered by Overland Accessories (out of business). It had been used for testing then ended up on the side of someones house where the cover took a beating (needs replacement). Besides that and the lining separating the two pads it is in overall very good condition. Only thing missing is the u-bolt assembly that attaches it to the cross bar. But can easily be replaced. You can mount with most rack systems or Thule/Yakima crossbars. Add $100 for a set of Yakima cross bars.
roverdudeATsbcglobalDOTnet
More details:
The floor is made from FRP which is fiber reinforced plastic. It is typically used in industrial applications where strength and sanitation are necessary. The result is a very strong, lightweight floor that will not rot, mold, split, or mildew. The ladder is load bearing and is the main support when unfolded. If you did not have the ladder down it does support itself, however, you cannot put any weight in it. When unfolded the hinged area is supported by a steel "Z" bracket.
Packed it it 48” X 55” X 11”. Unfolded 96” X 55” X 47”.
Tent: 210-denier Polyester Oxford with a 1500mm PU waterproof coating
Rain Fly: 210-denier Polyester Oxford with a 1500mm PU waterproof coating
Base: 2mm Light Weight base
Poles: Aluminum
Ladder: Adjustable Aluminum
Cover: PVC coated 210-denier Polyester Oxford with a 1500mm PU waterproof coating
Mattress: 65mm High Density Foam
More details:
Poles: Aluminum
