xpdishn
I recently bought a used Roof Top Tent, have used it quite a bit and really like it.
But a couple of problems have reared their ugly heads. I am hoping that others here can chime in if you have had the same problems and what you did to fix them.
The first is the cover zipper, actually the zipper on the tent itself, at the corners. The sewing has failed which prevents the cover from zipping all the way closed. My wife will be resewing the corners to see if that will take care of that problem.
The second are the plastic clasps that tension the rain fly to the tent. Pics below. We had a windy night and the next morning discovered that the metal stays had come out the pockets in the tent. That's when we found the broken clasps. I tried to tighten the stays by pulling of the straps and with very, very little tension the bottom part of the clasps broke. The amount of tension could be described such: 'By just looking at them, they broke." The pics should show the problem:
General view of the rain fly and tent
The next 3 show the broken clasps:
This one totally broke, though it doesn't matter if it is a partial break or total, they don't work in doing the job.
Those clasps are critical in keeping the rain fly and the whole tent together. Hopefully there is a solution for this.
It seems to me that the plastic is not UV resistent and shouldn't have been used in the first place. Metal clasps should have been used.
I am e-mailing Roof Top Tents with the same info to see what they say.
Any feedback will be appreciated.
Curious: is this tent the same as Camping Labs? Mombasa?
Gary
Gary
