I want to share a new spigot I've been working on for my rotopax water can. There isn't a great solution for this that I'm aware of, so I've started working on my own setup. It's very close - I just need to update the adapter material to ones that are food-safe (thinking aluminum)
on the left is my adapter washer. Currently made out of plastic that's not rated as food safe (although it is PVC plastic so I'm sure it's fine) and on the right is a brass spigot with 1/2" mounting threads.
The adapter replaces the yellow nozzle from the rotopax and uses the black O-ring from it.
All assembled
It doesn't sit flat with the spigot installed, so that may be an issue for some, but not for myself.
I also installed this vent that so water flow isn't impeded. it comes with a water-tight cap as well. It's hard to see but sits on the top corner above the spigot.
Mounted up on my Rigd Ultraswing.
Anyways, hopefully, that'll help someone out there. It's all very easy besides the adapter which I had to make. I'll keep you all updated on how the aluminum one comes out.
Links:
Spigot
Vent
All assembled
Links:
Spigot
Vent
