RRC half shafts wanted
James86004
I am having trouble located a set of used half shafts for the rear of our 1992 Range Rover. These are the 10 spline ones for ABS, used on 1990 to partway through 1993. I want to put something stronger in there, but don't want to rush the decision and need to get mobile. New ones are expensive enough that I want to consider alternatives.
I have one friend who sent his to the recycler last month, another who has a set but couldn't find them after looking all weekend. And I also have a lot of other people who have offered their 24 spline or non-ABS 10 spline shafts.
Thanks,
James
getlost4x4
go to the junkyard. get a disco 24 spline diff and shafts. It'll work fine with the ABS and be stronger.
I did it to the front of my 1993. It had 10 spline shafts up front for some reason. I've since done it to the rear as well.
James86004
I would do that, but it has a locking diff which I would lose. Yes, that probably contributed to the breakage, but the PO installed it 15 years ago, we have owned it for 6, so I would say the shafts are strong enough for on the order of a decade.
James86004
Both. The long side twisted and failed, the short side is also twisted but still capable of transmitting a wee bit of torque.
craig
Call Gord'n Perrot at Lamorna Garage in Seattle. He used to have about 20 of each.
James86004
There's a name I have not heard in a while. I didn't know Gord'n was still around.
I managed to source a set out of Arkansas, so I I set for now.
Thanks,
James
