On my trucks I’ve always sworn by Line-X. I did the interior of a blazer with Herculiner once, while very strong/hard it wasn’t thick and never seemed to build enough for any sound deadening. Sold the truck after 2 years so I don’t know how well it held up.
I recently tried some RustOleum spray on liner as a test for the inside of my trailer. Roughed the paint with a scotch brute on a die grinder, wiped with acetone. Dried. Then sprayed a flash coat followed by 2 coats following the can directions. 24 hours later and I can scratch the rubber surface with my fingernail. It easily peels off the paint (not cleanly in sheets, but easily) with a pocketknife.
Is this expected or is something wrong? Will more cure time help? Did I just choose product poorly? For $8 I thought it was a good experiment that might help with the slow pace I tend to use on projects. Spray cans let you do 1 panel at a time with very little prep or cleanup and a beautiful finish.
Anyone else have an experience to share?
