RV 4x4 Conversion
VikingVince
I've been following and investigating the motorhome scene for at least 10 years and I did not know this existed until the other day. The only 4x4 motorhomes I was aware of were Xplorer and Tiger CX as well as the expedition rigs built on Fuso,Mogs etc. Salem Kroger can convert most Class B and C (and some Class A) motorhomes to 4x4!!! This opens up more easily affordable possibilities. A small Class C diesel 4x4 on the sandy beaches of Baja...yeah, I'll stay all winter!
www.salemkroger.com
You should probably check out http://www.sportsmobile.com as well. I have been to their factory in Fresno, it's pretty darn impressive. They doe their own conversions using Dynatrac axles and Atlas transfer cases. Bullet proof combo if you ask me!
Mario...yeah, thanks,I forgot to mention Sportsmobile...guess I don't think of them as motorhomes...although technically they are a small Class B...but I've known about them for years and they are very nice units and very offroad capable...about $90K for a fully optioned vehicle
Clynn...I think you're right about the Chinook Baja...they have a pic of them on the motorhome page...I drool over those units as well...a fully optioned Chinook Baja tops out close to $200K however!!!...I think there's better value elsewhere.
Visit?...Hell...once I get the RV office setup with moto-sat, laptop, etc, you can work from the RV and stay all winter!!!!!!!!:arabia:
Sounds too good to be true :)
Dave, I like the hilux campers. We had discussed that first white one some time ago and wondered if the frame flex would cause any issues with the cab-to-camper interface. Pretty cool looking rig.
My FJ Cruiser conversion...
Complete with stretched wheelbase :)
Love that FJ Cruiser conversion!!
Dave...I know what you mean re the van conversions...in fact, Sportsmobiles are built on van chassis. Eventually, however, I want a unit that's more long-term livable, i.e dedicated bed area, couch, toilet/shower,kitchen and dinette area...in other words a motorhome or expedition rig. True expedition rigs are very expensive...a good compromise is a 4x4 motorhome with upgraded suspension, tires, and winch...although not really offroad capable, the 4x4 option would allow you to go on sand and get though some situations where you would otherwise get stuck. The main problem with motorhomes is the lack of a subframe between the cabin and frame rails to isolate the torsional forces of chassis articulation from being transferred into the cabin and breaking things. The RV industry should wake up and realize there's an unmet need/demand there!!!!!
The one I saw had a piece of flexible rubber about 6" wide between the cab and fiberglass. If you look closely on the white one, you can kinda see the gasket as it transitions from the back of the cab to the camper itself. I would think it'd be something you want to occasionally check, but it seemed no worse than the transition on any other conversion, like the van body to fiberglass on a Class C. The back of the cab was cut out and the gasket was solidly attached to both the metal of the cab and the fiberglass, it was pretty bomber.
The Innovations Camper one is a body separate from the cab, so that's just a utility body and so there's no connection between the existing cab and the camper part.
OK, I got it, Vince. Here's what you're thinking, then:
http://www.earthroamer.com/main_truck/vehicles.html
We've had this fella speak at a club meeting (Rising Sun 4WD of Colorado). Pretty swank set up he's got going. It's extremely capable (easily handles stuff like a White Rim), but not cheap. Figure ~$150K for one. But I'd still think this would be cheaper than trying to convert something to 4WD. I dunno what a Class C goes for, but by the time you buy that, stiffen the chassis and do the 4WD conversion, it's got to be in the same financial region.
Dave...oh yeah...Earthroamer...I forgot to mention them too...I've drooled over them for several years now...the going price for a fully optioned Earthroamer is right around $200K now!!!
I was thinking buying a used Class C for $25-30K...there are lot of used Winnebago Minnies (Ford chassis) in that range with low mileage...and then converting to 4x4...have no idea what the conversion costs...$10K?...from what I recall I believe Quiqley 4x4 van conversions run around $5K...so I'm guessing that the Class C 4x4 total project would still be ALOT less than an Earthroamer...like around $40K total, i.e. with a used RV...that's palatable!
His trucks are quite something, but far from cheap!
Yeah, definitely I'd think that converting a used van or truck chassis over would be /significantly/ less money (and more fun) than a turn key. I think that's a great plan. If you start with a E350 platform, I think figuring $10K would be fair. I dunno much about such conversions beyond a SAS, but if the chassis was available with 4WD, then I'd think it would be feasible. I mean, it's obviously done already, so maybe there's even kits available. It's a matter of spring hangers, a transfer cross member, some sheet metal work, driveshafts and lots of cutting, measuring and welding. It's not exactly rocket science, afterall. Cool idea!
How about custom body mounts? Isolate the camper from the frame and add in a piece of flexible material between the old van cab and the fiberglass. Leave the hockey pucks for the driving part and for the camper maybe use something like the dampers that they use on OTR sleeper trucks with the mini shocks and air bags
G35Vortec,
Very cool looking rig, how about some more pics/specs?
-Edit: Just saw it in another post.
rocksandtrails
