Sale or Trade - 2008 Ford E-350 Quad Van 4x4 - Low Miles - Price Reduced
Do you think this vehicle is priced right?
  • Too high
  • About right
  • Too Low
Results are only viewable after voting.
lakowskj
Hey Everyone,
This is a truly off-grid vehicle with great power, cooking, and water storage capability. The shorter wheel base allows you to go anywhere and make tight maneuvers.
I'd be interested in a trade for something that has more seatbelts.
Reduced Price - $85k
Please send me a message to get in touch or call/text 541-740-7083.
Full set of pictures: Pictures
Summary:
With a robust solar/lithium system, heating system, independent off-grid A/C, indoor and outdoor kitchens, and true off-road suspension this van is incredibly well-suited for a lot of adventures.
The Van:
  • Ford E-350 Standard length
  • 5.4L Triton V8 – 70k miles
  • 2008 with a 2020 Passenger Van conversion
  • Purchased with roughly 65,000 miles prior to the conversion.
  • Total loaded weight is 8200 Pounds
  • Total length bumper to bumper is 18FT
  • Total height is 10’ 2”
  • Fuel economy around 14mpg at 60 MPH
  • GCWR of 13,000lbs.
The Drivetrain:
  • 3.73 Gear Differential (speedometer almost spot on)
  • NV271 Heavy duty transfer case
  • Dana 60 Front and rear Axle
Suspension, Wheels, Tires:
  • Timberline vans 6” coilover linked 4x4 kit
  • Elka 12” travel bypass Stage 3 Coilovers – 500lb Eibach springs
  • Bilstein 5100 Rear shocks with Timberline 12 pack rear leaf springs
  • Van was originally converted to 4x4 in 2008 by Quad Van of Oregon and was upgraded to the Timberline Coilover kit during the 2021 conversion
  • Buschwacker Fender flares
  • 17in Method 305s in Bronze
  • 33in Kenda Kleaver R/T
  • Custom Front and rear Trac Bars
  • Front Heavyduty swaybar with extended Links
The Camper:
  • Custom R20 Morey Industries Fiberglass Hightop - Interior height – 6’ 2”
  • 3m Thinsulate and Closed cell Foam complete insulation of floor, walls, and ceiling- Comfortable far below freezing temps and cools easily in Arizona heat.
  • Complete cab and chassis vibration mat with Noico sound deadening
  • Marine Vinyl insulated woven flooring
  • Stainless steel Entry trim separating camper from driving cab
  • Custom upholstered/insulated interior door and window trim
  • All Custom lightweight Birch and Bamboo cabinetry
  • Isotemp Cruise 49 black Marine 12v /120v fridge/freezer
  • Thetford Triple Burner Propane Stainless Cooktop with glass top
  • Thetford matching glass top Sink Unit
  • Under bed and inside dinette latching storage compartments.
  • Rear outdoor Zero Declination Shower Stall with Stainless marine hardware
  • Toilet stall with Dometic Compact Cassette toilet
  • Dinette Seating with Bamboo table with flush mount wireless phone chargers
  • Modular aluminum and Birch bed platform. Bed Extends to a full ( 75x54 )
  • 2 piece Temperpedic 3in memory foam mattress
  • Custom made memory foam Dinette cushions and mattress wrapped in easy to clean marine vinyl
  • Complete dimable LED lighting system with RGBW bed mood lighting flushed into aluminum trim accents on ceiling – with touchscreen controller
  • Fresair 12v evaporative rooftop AC
  • 5 total Interior 120v GFI Dual outlets with USB charging and wireless tabletop charging
  • 12v USB charging stations
  • Full pull-out rear kitchen / barbecue unit - Contains flip out propane cooktop and sink with infrared barbecue station.
  • Custom door panels with first aid storage / tables / and cutting board
  • AudioEngine A2 Bluetooth sound system
  • Pedestal rotating passenger seat kit
Armor and Recovery Gear:
  • Aluminess front winch bumper
  • Aluminess rear bumper with hitch receiver and storage
  • Smittybuilt 15k front winch
  • Aluminess Side mount roof / solar access ladder
  • CARR offroad entry Steps
  • Complete underside refresh – included media blast and full rubberized corrosion resistive coating.
Lighting-:
  • Pair of Baja Designs S2 floods on Hood Mounts
  • Hella flush-mount bumper Pencil Beam Halogens
Power System:
  • Autarky Standard Solar Kit – AutarkyEv.com
  • 300W Flush mount Rooftop Solar array
  • Orion 30 Amp Alternator DC to DC charging while driving
  • Victron 100/50 Bluetooth Charge controller
  • Victron BMS with Shunt – Interior controller
  • 2000w Victron compact Inverter Charger with Cerbo controller and GX50 touchscreen
  • Midnight Solar Baby box with charge controller and inverter breakers.
  • 200 Amp DC disconnect
  • 30 Amp 120v interior accessible breaker panel containing all circuits both AC and DC in one easy to access and maintain panel.
  • 300ah Ampertime Lithium Battery bank
  • All mounted below rear dinette bench seats
Water, Heat ,Cooling:
  • 35 Gallon Fresh water tank – SS marine inlets
  • 8 Gallon Grey water tank – exterior Dump outlet
  • Shurflo 12v Water pump
  • Full Pex Plumbing
  • Rear mounted Stainless Shower system – hydronic connected for instant hot showers.
  • Rear mounted and enclosed 20lb Composite Propane tank – Only used for cooktops
  • Main Gasoline tank connected Eberspacher Ds5 Hydronic system - Instant hot water heat exchanger and Kalori thermostatically controlled in cab water to air heat exchanger.
  • Eberspacher easy start pro controller
  • Rear bumper mounted all aluminum hydronic tank for easy service
  • All plumbing and tanks are mounted within the insulated interior and will not freeze while camper is heated
  • Fresair 12v DC Evaporative cooler with separate 8 gallon water tank.
  • Custom Gold reflective heat shields for every window in the camper
Thank you!
Joey
541-740-7083
greatwhite24
